Posted: Fri Feb 16, 2007 9:58 am
Thank you for bringing this into our attention but this function did not got externalized for DCAL and hence this problem.
You can download and install depends.exe from http://www.dependencywalker.com/. Launch this application and browse to open Dcadwin.exe. With Dcadwin.exe selected on left side pane will display all available functions on the right pane (2nd from top). Anything not listed in this pane has not been externalized. Even problem with case sensitive names can be found using this application.
