Posted: Mon Feb 19, 2007 8:58 am
When (Del) is pressed brkprss returns a value of -1; when (End) is pressed returns a value of 1.
Usage: To terminate out of loop. In some cases if a break has occured internally, this value is returned in one of the variables.
to go into infinite loop until (End) or (Del) is pressed.
Hatchmode api returns this in brk variable.
More info in DCAL manual. Search for "brk"
Code: Select all
while brkprss=0 do
draw()
