Advanced Stamps
Posted: Tue Mar 18, 2008 1:39 pm
Does anybody know of a way to insert a stamp like the "Path+Name+Extension" (@DWGFULLNAMEEXT) stamp into a symbol, so that when the symbol in inserted into a drawing unexploded, the stamp will show the path to the symbol it was inserted from, not the drawing it's inserted into. Using the @DWGFULLNAMEEXT stamp in the symbol, and then double clicking on the symbol to edit it the stamp shows the path to the symbol while editing, probably because it's really a drawing at that point I'd guess. I tried a few things like @DSFFULLNAMEEXT and @SYMFULLNAMEEXT with no luck. If this is not possible yet, I hope it's something do able that could be added at some point. TIA.
I am still trying to figure out a way to do the above. Is there somewhere I can look at a list of the available codes we can use? It looks like the pre-made stamps are using DCAL Procedures, is this correct? Or are we limited to using the user created stamps which are limited to simple text substitution set by the UserChangeTo_1= line or using combination of the pre-made stamps?
At this point I would settle being able to open a symbol for editing, insert the DwgFullName=@DWGFULLNAME stamp which at that point works, and being able to "expand" it to dumb text and then save the symbol with normal text. I tried plugging in some newer symbol related procedures from StudioPM's Raw DCAL Notes as I found dwgname listed there and in the old Funclist.doc but I couldn't seem to get any results. If it's not possible on my end as of now that's fine. TIA for any ideas.
