Dcal Classic
Posted: Mon Jan 19, 2009 5:30 am
Hello,
The f6 Link option needs to take into account the linking of modules.
For example I have a program detailer.dcs which uses symcreat.dcs and menuscal.dcs. The latter two symcreat and menuscal are declared as MODULE in the first line of their source code, detailer is declared as a program.
When linking, the first name used by dcl.exe, must be a program. The module names follow seperated by a comma, the list being terminated by the ';'
So the development involves compiling the dco files for each and then creating the .dcx file (In my case detailer.dcx) via the command:
dcl detailer,symcreat,menuscal;
Modules are often developed as PROGRAM in the development testing process; but then will be recompiled as MODULE to form the .dco file.
F1 Init New should simply allow the user to start a new PROGRAM, or MODULE. The inclusion of #include files in a default new application is unnecessary. A lot of the procedures included in the INCLUDE files are now BUILTIN the compiler.
Regards
Rod Walker
Regards
Rod Walker
