I upgraded to X3 from DataCAD 11. I had DCAD 12 Test Drive loaded at one time.
After the upgrade to X3, the Icons for my DWG files remained the 11 icon before I chose X3 as the default program.
When creating a new file or importing a DWG file, DCAD immediately jumps to a file already open or to the empty DCAD screen.
My X3(13.05.01.06) does open old and new DXF files properly. DXF files are listed with the X3 icon.
Under "Open With" I do have a DATACAD.exe option w/ the 11 icon before it.
I have yet to try to open any old DWG's with my 11 Hardlock in place. (If I choose DATACAD.exe I get the "Hardlock not found" window)
Even files I have exported to DWG format in the past will not open, nor files I have received and opened in the past.
Please advise.
Does this sound like a complete un-install / re-install procedure is necessary?
I would like to eliminate the inconvenience to my AutoCAD associates having to call back and ask for different formats.
Not to mention losing the ability to review the older files.
Please advise.
