forum.datacad.com • View topic - head arrow in dimension
PostPosted: Thu Mar 14, 2013 2:15 pm
by damian
When I transfer a file dwg for colleagues working in Autocad, I realize that in dimensions, the head of the arrows is squashed and expanded.
If I use the full dot in Autocad is empty.
Is there a way to fix this?
Re: head arrow in dimension
PostPosted: Thu Mar 14, 2013 3:07 pm
Hmmm yeah this should be addressed if this is a typical result.
PostPosted: Fri Mar 15, 2013 3:47 am
by damian
I noticed that this only happens with associative dimension, probably because with associative dimension off, they become simple arrows and correspond well in autocad.
