forum.datacad.com • View topic - GTV's to dwg
GTV's to dwg
PostPosted: Tue Feb 04, 2014 2:09 pm
by rogerra
Question: When exporting a dcad drawing to a .dwg, how do you save the GTV's?
Re: GTV's to dwg
PostPosted: Tue Feb 04, 2014 2:35 pm
GTV's are not directly supported in Autocad. For our setup we use one file, with each sheet as a GTV, so we select our first GTV, then File, Export, DWG, On Layers and Save the DWG with the name of the sheet. We do this for each sheet. Would be nice if they could be translated to 'named views' on export for sure.
Re: GTV's to dwg
PostPosted: Tue Feb 04, 2014 2:42 pm
by rogerra
Josh,
Thanks. That's what I have been doing.
I thought, by now, there might be a better way.
Roger
