problem dwg
Tue Jul 18, 2006 6:49 am
by marko
There is a problem dwg that DataCAD fails to open/import for some reason:
http://www.hirvesoo.ee/problem.dwg (270KB)
Does anybody have an idea what can be wrong with this drawing?
Tue Jul 18, 2006 9:06 am
by Bruce111
Hi Marko,
It seem to open OK with Version 11.08.01
What version of Datacad are you using.
Regards
Bruce.
Tue Jul 18, 2006 10:23 am
by MtnArch
I'm guessing that Marko is in DC 10 as I was able to open it in V11 like Bruce.
I've PM'd Marko so that I can send him the converted DC file and get him back to production.
Tue Jul 18, 2006 11:16 am
by marko
I'm using 11.08.01. I tried to both import the drawing and directly open it, but in both cases DataCAD analyses the file, counts entities ...100% but then suddenly gives no more response
Tue Jul 18, 2006 11:30 am
by marko
Thank you, Alan! The converted file is perfectly OK and now I'm back on track - - -
Tue Jul 18, 2006 11:31 am
Hello Marko,
Are you using the "Move to Origin" option? If so, try it w/o and then move things afterwards.
Also, you can hit End to "unfreeze" it, though it won't have imported anything...
Tue Jul 18, 2006 12:17 pm
by marko
Neil,
Thank you for another hint. This really seems to solve the problem. I unchecked the "move to origin" option and the original problem dwg opened smoothly.
