Like TEXT OUT OF ALIGNMENT WHEN IMPORTING DWG FILE FROM SURVEYOR #13721 by msharch Thu Sep 14, 2006 1:46 pm The text is all out of alignment with the plan when importing my surveyor's dwg file into dcad 11. I hope there is a solution to this. Thanks. Marc Marc Hershman MSH Architecture Associates Username msharch Posts 37 Joined Sun Apr 03, 2005 1:16 pm Location Newton, MA Contact
Like #13726 by Neil Blanchard Thu Sep 14, 2006 2:15 pm Hello, Move the file to the Absolute Zero point, and see if that helps? You can do this either by checking the option when importing, or just Move everything while in Absolute Cartesian/Polar. Sincerely, Neil http://neilblanchard.blogspot.com/ Username Neil Blanchard Posts 8358 Joined Fri Feb 11, 2005 11:24 pm Location Maynard, MA, Eaarth Contact YIM
