Dear All,
I am preparing drawings using Datacad for a company which uses autocad.
The following pen colors translate direct to their system without a problem-Red, white, green, blue.
The remaining autocad colours that they use regularly are yellow, cyan, magenta, 8 and 9 (the last two being light greys) which do not convert correctly.
Can someone help me with the conversion selection in the DXF/DWG color map please.
Allan Kent
Allan Kent
