exporting reference files
Fri Nov 21, 2008 5:57 pm
by wolverine
Is it possible to export a reference file, specifically a bitmap/image of a logo.
Need to export as a dwg (for autocad), and I see an option for automatic export of reference files on the export menu, but all that shows up is a box?
Using V.11
Thanks-
Sat Nov 22, 2008 6:17 am
by Bruce111
Hi,
Just a thought . Can you explode the box and get the bitmap to show.
Sat Nov 22, 2008 10:11 am
by wolverine
Well, I need this to show in in a cad viewer such as Bentley or VoloView, no way to manipulate the file.
Mon Nov 24, 2008 9:10 am
by csmckillip
I have had NO luck in having the bitmap stay in the file. Autocad uses the command "image" to inset into the file. I would have someone with Autocad update the file with the bitmap.
Tue Nov 25, 2008 5:40 am
by Bruce111
Hi,
It would seem that DataCAD uses a completely different method of displaying images than AutoCAD does, and the two formats are unfortunately not compatible.
Thu Dec 04, 2008 5:25 pm
by Design&CodeGuy
I am glad you brought this up. I am fighting with the same problem.
There must be some way to bind images to the file.
