It has been my experience that, that text issue happens. Autocad and Datacad text settings work differently and that is just the way it is. I also send the engineers/consultants a pdf file for viewing and printing and a dwg file just for there backgrounds. They don't need our text for there work. Plus sending pdf's is better. You don't need someone out there "altering" your work.
Arthur Wood
CADD Manager
EH Danson Associates
St. Johnbury, Vermont
CADD Manager
i havent noticed the text enlarge when i export to dwg, but the aspect ratio of the text does change, because dwg uses a measurement that is opposite to datacad when it comes to changing the aspect ratio. Now i just try to use a standard font, that way the shift is minimal when i do export a drawing. I know that sending sending the team pdf's is alot easier, but on our projects we need to share drawings for coordiantion. We xref mech, and struct. backgrounds and the engineers xref our arch backgrounds into their drawings. if you are exporting for coordination, the text issue shouldnt really matter, most of the text layers will be turned off by the engineers either way, and if you are exporting for plotting, i think pdf's should be the way. Just my 2 cents.
Nelson Cordero
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
would be much appreciated.
BTW, the online list of codes ends at 1084+3015, my running list goes to 1092
https://www.datacad.com/ddn/extended_cha ... codes.html
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
Ya know I have been complaining about this enlarged text issue ever since I can remember and it STILL doesn't work correctly or the way we would expect it to work. Seems silly as hell that something as basic as text which is a HUGE part of our drawings can not work correctly between programs. It is even worse when it is a drawing that originates for AutoJUNK then comes to DataCAD and then back to AutoCRAP... the text is all whacked out. Change anything with a line of text and it magically moves up a tad?!?! Silly.
Have I ever told you how much I hate autostaph?!?! BUT when I use DataCAD and export to the junky program I end up with more junk that I am assuming is created or whatever in DataCAD... Once again, silly.
Here is to wishing there is some sort of fix for this mess. Text is a major part of the process and I shouldn't have to stick with some basic font to hopefully make it work... which in most cases still messes up.
Kent
Kent
