V11
Wanted to view a roofline .... opened up o2c and had an empty screen.
It was working fine last week.
Opened a new drawing and put a slab in, with the same results.
Tried "show all' .... thinking it was off screen somewhere, nothing.
All lights are turned off in "Shader"
The viewer opens as normal but model is not there.
Joined
Tue Nov 14, 2006 7:40 am
All I can think of is maybe your rendering settings for the slab have an opacity of 1. This makes it virtually invisible.
Dan Martens
NBF Architects
Rutland, Vermont
Joined
Thu May 19, 2005 7:29 am
Even though you cannot see anything, try saving the object and looking at it outside of DataCad. If OK it suggests that o2c isn't kosher.
Try looking at the model in a previous job. If OK it suggests you current job isn't kosher.
Try importing a known good model into the current job. If OK it suggests there is something wrong with the file.
It only takes about one minute to re-install o2c.
Nick Pyner
Dee Why Beach NSW
Joined
Mon Mar 28, 2005 9:53 pm
The render/opacity setting was at 100.
Reinstalled o2c player from CD, and it is working again.
Thanks for the replys.
Joined
