o2c object to webpage
Fri Jul 16, 2010 10:26 am
by dannac
I can view o2c objects on my webpage using IE.... but cannot view
using Firefox.
When opening the webpage in Firefox it tells me I need a plugin,
clicking to get plugin tells me
"no suitable plugin found"
Sun Jul 18, 2010 12:52 pm
I've never used it but there seems to be a O2C plugin here, but I think someone recently metioned they couldn't get it to work. Good luck.
http://www.o2c.de/cms/en/index.php?a=135
Sun Jul 18, 2010 3:45 pm
by Daniel Kaczor
I got it to work in FF using the manual approach. Don't install automatically and don't upgrade when asked. When you see -""The o2c-PlugIn for Firefox should be automatically installed, when you visit the o2c-Startpage. If not, you should do the following.
Download the xpi-File: Download o2cplayer.xpi (as zip-archive) Choose
Extras -> Addons in the Firefox-Browser. A Windows opens, that Choose
Extras -> you can drop the xpi into. Click on "Install", when Choose
Extras -> the button is not greyed any more.
Now you can see o2c-objects on Sites, that have changed the html-Code in a way, that the Firefox-PlugIn is included."
Follow the part that I enlarged. Drag and drop the o2cplayer.xpi file onto the Add-ons window, you will get another window to install now. Should work after that.
Mon Jul 19, 2010 7:32 am
by dannac
Thanks for the replys ....
I will try your suggestions when I get a chance.
Funny thing is I tried the web page on another computer running
FireFox and it showed the o2c object first try ... no interaction with plugins on my part. ( no interaction from me probably a good thing)
Mon Jul 19, 2010 2:39 pm
by dannac
No problem installing the plugin from site given above.
Problem was from computer not having DirectX installed.
