02c has started to hang and crash DC. Worked fine for weeks. Recently, though, it hangs a second after 3d movement is begun but then works fine the next time around if I go directly back into it. This sequence then repeats on the next use. Different drawings behave the same, larger or smaller.
I have gotten crashes also. I reinstalled the viewer from the DC website and found the older one works better
I know on some older versions when the poly count gets high, things started crashing. I was told O2C was for object viewing, not complicated renderings. I don't know if that holds true still or not with the latest versions.
Thanks! - Josh
