Hello Guys (& Girls),
Sorry for the image size, but I guess it worths.
Here is an image by the office of Franklin Moreira Architects, from Porto Alegre, Brazil, who uses DataCAD since the early 90's.
Symbols were remade with alternate settings, using several curved polylines, filled by colored solid fills, in varied shades, pretending to be gradient.
The use of symbols with bitmaps is a bit less handy because it requires that the source bitmap to be at a unique reference address.
If you transfer the drawing to another machine you should take care of this.
The ground surface is filled by inserted bitmaps handled by Move/Down/Up.
The .PDF ready sheet is really great, because it takes all the adjusted appearance from your original workstation, and the customer loves it.
Miguel
