Can you render a front elevation (2D) in O2C without having to convert it to 3D ? What is the quiickest process ? We purchased O2C and now need to get some help on to use it to best fit our firm.
Thank You.
Amy
Thank You.
Amy
Emc Downunder wrote:I have used o2c to create colour elevations, which were just for presentation and it had no notation, if you generate a colour elevation, with shadows, you may be able to save that image and import that into datacad set it in behind your drawn elevation.. just a thought.. might have to try it out to see if it would work..
