the o2c modeler is great. I keep hearing about the walk-throughs other users are creating and have been very unsuccessful in doing one myself. Any help would be greatly appreciated. Thanks.
After you open your model in the Object Viewer, right click your mouse to access the context menu. Choose Walk Through to change to walk through mode, then use the mouse to move about the model. It will take some getting used to, but you can always right click and choose Show All to start over from the beginning.
Mark Toce
DATACAD LLC
DATACAD LLC
If you want to save the walk-thru, download Bulent's Screen Recorder to capture the o2c window as you move around in your model. It is free, download at http://www.thesilver.net/
--just wandering-
dmartens wrote:I keep hearing about the walkthroughs other users are creating and have been very unsuccessful in doing one myself.
You may find the "Working With Views" Viewlet helpful for instructions on using the various walk-through commands in o2c. You can access it on the Viewlets page at:
http://www.datacad.com/support/bulletin/Viewlets/viewlets.htm
FWIW,
MFM
