#42133 by Bob Urbanek
Sun Mar 15, 2009 10:49 pm
I modeled a corner shelf unit. When I try to rotate itin o2c it goes right off the screen. Is it possible to set the center of rotation so that it will rotate in place?
Bob
#42135 by Mark Toce
Mon Mar 16, 2009 5:07 am
DataCAD determines the center of rotation automatically by calculating the extents of the objects in your model. I suspect you have a light source that is positioned away from the rest of the model.
In DataCAD, go to the 3D Menu and choose Shader. If any light sources are turned on, you can either turn them off or reposition them closer to the model. This should solve the problem.
