The problem I have now is, I used to have a quick-Key set up for 1 line trim (Alt+V).
I don't know about you guys, but I use "1 line trim" ALL the time. Even more that (Alt+F) for fillet. Problem is, when I set that up on my old machine, it was so long ago, I don't remember how I did it. Now that I bought my new ASUS TUF laptop, I have tried to read a few threads here on how to set up a quick-key, or shortcut, or however you want to call it, and it is not working. Alt+V still takes me to 3D views menu.
When I open up DcadWin.MNU, I look for "1 line trim". It is line 40, and there is nothing between the "pipes". I added |Alt+V|, saved and closed, opened up DataCAD19, and held Alt +V, and it took me straight to 3D views. I go back to the DcadWin.MNU file and search for 3D views to see if Alt+V is listed prior to line 40... it's not anywhere else (besides line 40 where I put it) on the list!
What the heck am I doing wrong?
The thing that kind of erks me is, I know I can't open up DataCAD on my old laptop. I deactivated it so I could activate it on my new laptop. But I can still get into the file system on my old laptop. So I did. I opened up the DcadWin.MNU on my old laptop, and the "1 line trim" on line 40 over there doesn't have anything between the pipes EITHER!!!! How did I DO THAT ON THE OLD LAPTOP? How did I make Alt+V take me straight to 1 line trim if I didn't change the DcadWin.MNU file?
