#3614 by Thogar
Wed Jun 22, 2005 11:55 am
Ever since we upgraded to Datacad 11, I've been plagued with this error message: "Datacad Internal Stack Overflow! Buffer Empty!". This happens extremely frequently, something like every 5-10 commands issued. When this error message occurs it cancels my chosen command and defaults back to drawing walls.
Needless to say, this has been frustrating...maddening even. I tried searching the forums for a post regarding this particular problem, but the search tool didn't return any results. If I am repeating a post, I sincerely apologize, but I also just as sincerely want to get this issue resolved.
Does anyone have any idea what I can do to try and remedy this problem? I'm using Datacad v11.07.00 and this very same problem has happened on every upgrade since we first installed v11. My PC seems to be the only one of the three running Datacad that has this particular problem, but all 3 machines are running the same hardware, OS (xp pro sp2) and version of DCAD. The only differences are the other 2 machines have slightly faster CPUs in them.
