To rejustify text that has already been placed, you use the Justify menu under the Text menu. You are prompted to draw the justification line, then pick the method of justification (left, center, or right) and then pick the text to re-justify. In versions of DataCAD prior to the addition of the Alignment menu, to reset the justification method and quickly get to "Select first point on the justification line" Toolbar commands, Keyboard Macros, or Aliases would look something like this (Alias version shown):
[jl]
comment=justify left
alias=^;^S6^S5^F1^F7^S0^S4^
[jc]
comment=justify center
alias=^;^S6^S5^F2^F7^S0^S4^
[jr]
comment=justify right
alias=^;^S6^S5^F3^F7^S0^S4^
In DataCAD 11.07, these reset the justification method in the Alignment menu, but not in the Justify menu. The values in the Justify and Alignment menus are independent of one another. Hence, the above Aliases don't work as intended.
Question 1: Is this a feature or an oversight?
Question 2: It appears that there are not any Extended Character Codes or Action Codes to force the justification setting. Am I missing something?
Question 3: These could be rewritten to first draw a "fake" justification line so that the justification method would then become available, then exit and re-enter to the "Select first point on the justification line" prompt. How do I write that sequence so that it would work in both Relative Cartesian and Direction/Distance input modes?
[jl]
[jc]
[jr]
