#4121 by deliriousga
Fri Jul 08, 2005 11:11 am
I want to be able to have two different ways to plot a drawing without having to go through the "setup", "scale", "pen table", "quick layout" routine every time.
What I want is one setting to plot the drawing at full scale with the heavier pen settings and one setting to plot it at half scale for in-office checking.
I tried the "multi-layout" function but it doesn't seem to save any settings and just uses what's currently selected.
Is there any way to do this?
Thanks!
#4125 by Daniel Kaczor
Fri Jul 08, 2005 12:48 pm
Hello John,
Use the Check Plot function, when you reduce the size, the line thicknesses reduce also.
Or, save as PDF then print to any size or scale in Acrobat.
#4126 by Paul Nida
Fri Jul 08, 2005 12:50 pm
Have you tried using the check plot feature in the plotter setup and set it for half size?
#4130 by deliriousga
Fri Jul 08, 2005 1:13 pm
I'll try that. See what happens when you put an amateur in charge? :roll:
#4143 by MtnArch
Fri Jul 08, 2005 10:16 pm
deliriousga wrote:I'll try that. See what happens when you put an amateur in charge? :roll:
Yeah ....
He uses a tool that actually DOES something useful!!!!
:D
#4363 by Steve Scott
Mon Jul 18, 2005 2:43 pm
Actually, we're stuck here. Yes, there is a check plot
function, but this is only a small partial answer to your
question. Multiple plot settings would be helpful for
different uses. I've always had many output needs
and jumping between them has required changing the
settings in every file before plotting. Having a separate
plot setting just for batch plotting would be extremely
useful.
#4364 by Miguel Palaoro
Mon Jul 18, 2005 3:18 pm
Hello Steve,
I would suggest the creation of several "Styles", that could be dynamicaly added to a drawing in each time we would need.
Styles that would cover Texts, Dimensions, Plotting and possibly several other settings.
This will be a good point for V12.
#4379 by AT2
Tue Jul 19, 2005 8:11 am
Where is the Check Plot function?
thanks
AT
#4382 by artmanvt2000
Tue Jul 19, 2005 8:43 am
The chech plot is with the plotter setup dialog box. It is in the middle of the dialog box.
#5263 by deliriousga
Wed Aug 17, 2005 10:38 am
Thanks for all of your help everyone. The check plot function works nicely since I can set it up and just click the dot for a check plot.
:D
Users browsing this forum: No registered users and 79 guests
