Loaded WinXP64 on workstation, and XP Aladdin Hasp and Hardlock drivers will not load. Where can one locate XP64 driver for the Datacad hardlock? Do I need to send the hardware lock back and switch for something else? Any help is appreciated, can't draw till I solve this problem
Hello Steve,
Try to find orientations on the Aladdin Website, here,
http://www.aladdin.com/support/hasp/enduser.asp
If this doesn't solves, I suggest you to ask for help directely from DATACAD's Technical Support at techsupport@datacad.com
HTH,
Miguel
