XRef Issue
Posted: Tue Apr 10, 2012 10:57 am
Greetings,
Yesterday as I was working in a plan for a small house, and I was toggling between the GTV for the 1st floor and 2nd floor, the XRef of the existing plan had all of it's layers turned off. The XRef is Highlighted to be dashed light gray lines, if that matters. I turned all the layers back on in the RFM, and the highlighting setting was working correctly.
