The way I use the plotting process in DCAD, it always creates separate PDFs for each MSP sheet that you plot. I don't know how one would actually print out all of the MSPs they want and have them merged into a single PDF. If I want that done, I use Acrobat to insert the separate PDFs created by the batch plotting operation in DCAD, into a single PDF file.
David Porter AIA
(DataCadder since v.2)
Select batch plot. Tick "Plot To Files" in batch plot and PDF format. Ensure you have selected GTVs or MUlti-layout sheets. Go.
The individual PDFs are made and suitably labelled. Use PDFills Tools Merge as required.
Nick Pyner
Dee Why Beach NSW
Dee Why Beach NSW
Tried that but it is still saving to a set file. I need individual pdf files. Not sure what I am doing wrong.
Also of note, make sure you do not have any periods in the GTV names.
Thanks! - Josh
I realized after posting that I had to change the location in preferences where the pdf's would end up. Is there a way to change how the pdf's are labeled? I do not want the quickview label on them. Thank you for your help on this.
Thanks! - Josh
Users browsing this forum: No registered users and 45 guests
