Section arrow option
Posted: Mon Oct 07, 2013 6:38 pm
When I choose the symbol option under the section menu the folder/symbol I choose is drawn but the size does not correspond to the size chosen. When I click on OK, exit then go back in to check the size once chosen, it does not reflect my original choice. If I let DCAD draw the arrow (auto option) everything works as it should. I may be missing something but when I choose the symbol option regardless of which value I choose from the drop down menu it does not reflect the choice I made but some odd choice that is converted to ft/in rather than a decimal equivalent which is what I am offered in the drop down. Any ideas?
