I am finding that a Fence that includes both end points of a line does *not* select the line. I tried it in Mirror first, and then in Move, and in both cases, the line is left behind, even though the Fence included both end points of the line inside the Fence. (I'm not able to use Crossing.)
Neil Blanchard wrote:I am finding that a Fence that includes both end points of a line does *not* select the line. I tried it in Mirror first, and then in Move, and in both cases, the line is left behind, even though the Fence included both end points of the line inside the Fence. (I'm not able to use Crossing.)
It worked when I tried it here, so please send in the drawing in which it happened. Let me know which line I should try to select, and where the fence was drawn.
