To all,
Thanks to all on the font sizing from DataCAD to SketchUP, all sorted.
Just one other query, in DataCAD I mostly use a font set called “ARCWY2TX” & “ARCWY2HC” and other variants, however in SketchUP, this font appears very thin & difficult to read on the single line strokes when printed. Of course in DataCAD this is no problem as one can alter a colour for line thickness. I don’t think you can alter font printing line weights in SU, so does anyone have a solution to this...
I’d use another font, but I was trying to match a SketchUP drawing to a DataCAD drawing for the same client to look the same. I’m now thinking to forget the SU-LAYOUT plan & import all into DataCAD. Perhaps there’s a Tru-Type font identical to these I could download from somewhere..
Over & out,
Clayton.
Over & out,
Clayton.
Trotman & Taylor Architectural Consultants U.K.
