I haven't used the 3d Site macro for a while and was needing it this week, but it doesn't appear to run in v15.03.02.02. Any suggestions? I assume that I have the entire dcx file, it is 116K in size. When I click to start, the menu at the top where it usually shows a choice between "utility" or "edit" and other choices, only says "Toolbars" and does nothing. The cursor is normal and the message bar says "Click first point of new line or wall"
