Hi,
In the latest version of v15, is there a setting/toggle/INI edit to get a GTV to automatically control the layers that are shown in an XRef? I thought this was the default.
Also, the trouble we've had in the past with this feature, is that if someone opens the drawing in an older version of DataCAD (that may or may not support this feature?) all the GTV's that use the single XRef -- all get switched to a single set of layers. Which is a bit of a nightmare to fix.
Can someone enlighten me as to the state of this feature? We cannot use this until it works smoothly, and unfortunately, once bitten twice shy!
