MText Question
Posted: Tue Oct 22, 2013 3:59 pm
Hi,
In MText is it possible to get lines of text closer together (vertically) other than by changing the size of the text? Or, is that something that is determined by the fonts used? Here's a screen capture:
The address font is Complex and each line in the MText needs to be farther apart. The Signature is a font called Brush Script MT, and the rest is Arial in italics. The original text entities are on the left inside the border, and the ones on the right are two MText entities; and the second one needs to have a lot less space between the lines.
