#62673 by wvar
Sun Dec 08, 2013 7:03 am
I know how to generate a section from a 3D model. However, I am unable to update the section if I change an option or the model changes. This was asked some time back. However I never had a resolution on this. Are anyone else having problems or is it operator error?
#62736 by David A. Giesselman
Thu Dec 12, 2013 10:00 pm
Walter:
I wouldn't be so quick to dismiss it as such. Please post the exact steps you are taking. If I can recreate the problem you are experiencing, the chances are pretty good that I can fix it if it's a bug. We're usually pretty good at that. We just need to be able to reproduce it. If needed, send an example drawing to techsupport@datacad.com with clear instructions as to how to cause the error.
Cheers!
#62742 by wvar
Fri Dec 13, 2013 6:19 pm
Thanks Dave
I will put together some info for you over the next week.
#65373 by dmartens
Mon Nov 24, 2014 10:56 am
So Walter did you get an answer to updating your sections? I am having the same problem. Thanks.
Dan
