Hi Dave, I downloaded the the hardlock file that you sent me but I still get the same error message that it's looking for hlvdd.dll. Have anything to help me with that? Thanks, Cy
I haven't run Win8 at all (Win7 is fine, thank you very much) but make sure you did NOT install V12 into the Program Files directory - install it into it's own directory (ie. DataCAD 12).
Highest Regards,
Alan T. Hendry, RA Intel i7-12700F (2.10 GHz) Desktop, 16GB RAM, 1TB SSD, Win 11 Home 64-bit, DC 23 w/ latest beta Intel i7-10750H (2.6GHz) Laptop, 16GB RAM, 1.5TB HD, Win 11 Home 64-Bit, w/ DC 22, 23 & latest beta
Hi Alan, I did load the program in the c drive, not program files. Do you think if I unload the program and reload after downloading the hardlock file that dcad sent me, it may do it for me? Thanks, Cy
Dave could answer this better than I, but I'm guessing it won't make any difference. My assumption is that for some reason the folder where the driver is located isn't being found, or it's not where it's supposed to be.
Highest Regards,
I'm guessing the v12 is just not going to work with Win8.1? Something was changed by Microsoft between Win8 and 8.1 maybe, and your best path is to upgrade to v16, I think.
Thanks Mark, I moved the file to sysWOW64 and now it states unknown hardlock driver rather than looking for hlvdd.dll, so I guess were making strides. Any thoughts to where I should try to go now? Cy
This is just a guess so consider it no better than that. When you right click on hlvdd.dll in the WOW64 folder, it will probably state that it is for an unknown program and there is a browse button with Change or something to that effect. You might point it toward DataCAD. I would think this might be directly related to our need to keep DataCAD out of the programs folder and Windows refusing to believe that any program would dare operate outside its control. Good luck. Woody
