I've read pretty much every post I can find on this and have not yet found a solution.
I'm trying to install version 11 on a Windows 7 64 bit PC and all that happens when I initiate the install is the install circle spins for a few seconds then just stops and does absolutely nothing.
I had this problem last year but managed to find a solution and get it installed, but for the life of me I can't remember what it was. I bought a new hard drive so I'm back at square one.
So far I've tried:
Run a windows compatibility troubleshoot trying older versions of Windows
Changed the default install folder from x86 to a DataCAD folder I created on the C drive
Transferring the install files from the disc to a folder on my desktop and a thumb drive to install from those locations
Any help I can get would be great. Thanks.
So far I've tried:
