I print on 11x17. When I hit that size it prints fine. When I go to select Borderless tabloid it enlarges it a bit and the scale is off, even though the percentage to print is set to 100%. This didn't always used to happen. What gives?
Printer driver updated lately? Windows updated?
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
You need to check that BOTH the Datacad "print"-command preferences is at 100%-factor...and that your selected printer's "print preferences" is set for 100% too.
If you are using a .PDF-virtual printer to make .pdf-files, make sure the "printer-preferences" are set to 100%. Sometimes they'll default to "fit"...especially if you have the "automatic paper-size and rotate" selected. The same applies if you are later printing-out at 11x17" the .pdf-file.
I've been printing construction documents at 11x17" for nearly 20-years as the "original record documents", and for small projects it's definitely the way to go. You just have to ration your drawing-page information-density appropriately and balance the type-size and line-weights for clarity and legibility. You may need more sheets than using 24x36" or larger sheets, but the repro-costs and the the ability to easily print-out and distribute as .pdf-files. outweighs the drawbacks of the small-format. You may also need to widen the actual page-margins slightly to compensate for typical 11x17" printer's mechanical limitations at the sheet-margins, but that's minor.
Depending on if ink-jet or laser, most are not capable of true "marginless" printing, they need a 1/4" to 1/2" mechanical-border when the print. You just have to allow for that when you set-up your page in Datacad. The target-boundaries at Datacad's "print - quick layout" compensates for your selected printer's mechanical limits....while a virtual printer-selected creating a .PDF-file will have target-boundaries the nominal page-size.
Most businesses or contractors have at-least one 11x17" printer somewhere in the office, and even at the local Staples or Kinko's it much cheaper overall than engineering repro.
Users browsing this forum: No registered users and 61 guests
