I'm sure I have seen this before, but can't seem to find it... Is there a way to explode the smart walls and doors when exporting to a dwg file? My dwg files are including door knobs, no door or window openings, etc. Thanks for any suggestions.
Joined
Tue Feb 15, 2005 3:19 pm
Location
Lawrenceville, Georgia
Under Program Preferences, DXF/DWG tab at bottom, check the left boxes for Mart Entity and Symbol export. You can also manually do it under Tools/
Roger Donaldson AIA CSI CDT NCARB abUsing Datacad since 1986, ver 23.00.02.15 (SE)
http://www .
R ogerD onaldsonA rchitect.com
Joined
Sat Feb 12, 2005 12:33 pm
Many thanks, Roger... For some reason it didn't work previously. I have been having a diagnostic fault error from 736 while exporting this particular file - I guess that is causing the problems
Joined
Location
