Text Questions
Fri Aug 15, 2014 8:00 am
Hi,
I thought I had things set so I always have All Caps in all situations - I have All Caps toggled on in the Text menu, and I have the DcadWin.ini option AllCaps Linked=TRUE. And yet, when I insert a symbol with Text Attributes, the All Caps toggle on the dialog is not on.
Am I missing something? I am now using v16.03.00.12 (SE).
Re: Text Questions
Fri Aug 15, 2014 8:22 am
by David A. Giesselman
Neil:
In the [General] section of the INI, add/modify the following key:
Symbol Attribute AllCaps=TRUE
Re: Text Questions
Fri Aug 15, 2014 8:27 am
Thank you, Dave!
Re: Text Questions
Mon Sep 08, 2014 9:18 pm
by gregg kett
hi there guys
while we are talking text does anyone know where to find the list of hotkeys for text symbols ?, I know that " alt 0127 " gives the degree symbol but looking for the centreline and others.
im using roman font if it makes any difference
cheers and thanks
rgs Gregg
Re: Text Questions
Tue Sep 09, 2014 12:10 am
by REX PEET
Go to pp. 605 & 606 of the Help Manual - there is a list of fonts that support extended characters and the codes on p. 606
Re: Text Questions
Tue Sep 09, 2014 1:06 am
by gregg kett
hi Rex
that's great thanks I found some other stuff there I was looking for as well.
Cool
cheers Gregg
Re: Text Questions
Tue Sep 09, 2014 6:14 am
by REX PEET
Glad I could help Gregg. I always use ARCWY2HC on drawings which looks trendy and supports extended characters. The other thing to do, to appear intelligent, is to print the extended character code table and glue it to the edge of your monitor. That way, the codes are always ready to hand, so you can look superior to all your chums when they ask you for a code.
