Using dacad 16 v 16.04 00 04 SE with inference snapping on (tried with off as well).
Editing a vertical polygon and trying to move the vertex to the intersection of 2 lines with a zbase and height, lower and higher respectively than the polygon.
The add vertex works but cannot snap to the intersection when using move vertex.
What am I doing wrong (something probably obvious) !!
regards
John
regards
John
