To all,
KnockOut by group..!!
I was drawing up a cut roof plan with polylines as rafters, but then decided to show the walling below. For clarity, I thought it would be a good idea to deploy the "knockout" to the rafters. However as many rafters, I was wondering if you could somehow deploy KnockOut by the normal selection method, i.e. by group, area or fence. However this isn't listed in the menu as far as I can see, so is there a way to do this on mass ? if not, then the normal selection method in the KnockOut menu would be great to see in the future.
Over & out,
Clayton.
Cool........
Thanks for that Roger, I knew there must be a way..........those 50 rafters did take rather a long time to do one at a time....
Over & out,
Clayton
Over & out,
Clayton.
Roger D wrote:Change / More / Knockout / Border and then pick by EGAF
Cool........
Over & out,
Clayton
Trotman & Taylor Architectural Consultants U.K.
