DataCAD 16 inaccuracy when snapping
PostPosted: Wed Sep 30, 2015 1:49 pm
by Devereaux
We are having a HUGE problem hitting snap points - unless you zoom in very close. This started to appear on our computers as we upgraded to 16.04.00.04. It's particularly bad on large projects where the discrepancies tend to multiply. The misses are so close that unless you zoom in - you can't even tell. Sometimes the "miss" even dimensions to zero.
HELP!!!!
Re: DataCAD 16 inaccuracy when snapping
PostPosted: Fri Oct 09, 2015 12:06 pm
by Rashid Garuba
These boards not read by someone at Datacad? Check your miss distance setting?
PostPosted: Fri Oct 09, 2015 1:15 pm
by MtnArch
Rashid - Mark M., Clay R. and Dave G. **do** read the forums! I think they tend to respond more to those who are on the current maintenance subscription, but they will respond to some of the older version posts as well.
Deveraux - I've seen this for quite a while as well, but am not sure what's causing it. My guess would be that DC is right on the border of needing to refresh the screen but hasn't. Maybe try that?
PostPosted: Fri Oct 09, 2015 2:20 pm
by Rashid Garuba
Good to hear Alan...
This does happen to me from time to time as well.. You work on a complex Roof that doesn't resolve then you zoom in and find a line that didn't snap to an end.
PostPosted: Tue Oct 13, 2015 4:37 pm
by Devereaux
My "miss dist" is set to 10 - but has little effect on the issue. The roof plan is an excellent example of our problem. It is not until you zoom in as far as possible that you see that the points do not meet.
