#67641 by wvar
Tue Dec 01, 2015 5:32 pm
Is there a way to keep SunShader or Object Viewer open while working on the model?
I thought there was, but must have dreamt it.
#67642 by joshhuggins
Tue Dec 01, 2015 5:40 pm
You can File, Export to a O2C model and use the external viewer, but it won't dynamically update as you make changes. Sun Shader seems to block input to Datacad while open.
#67646 by Mark Bell
Tue Dec 01, 2015 6:56 pm
Hi Wvar,
....you could undock one of the viewer windows (ctrl - W) place it on your second monitor then set auto-update and a 3D view you want with Shade also turned on then it refreshes as you change the model and works using the Quickshade.
#67654 by Mark Bell
Tue Dec 01, 2015 9:09 pm
OK, it doesn't offer what you were looking for but will allow some level of 3D view update in a separate window and you can continue to update the window with each refresh as you design.
Users browsing this forum: No registered users and 47 guests
