Wiggle line type
Thu Dec 10, 2015 12:38 pm
by beneastman
When I use "wiggle" line type the line appears with breaks in it, as though a dashed pen style were used. I have tried using change/more/pen styles and trying various options. Typical I use solid R or solid F but none seem to make the wiggle appear as continuous line. Also Ive tried setting different spacing settings etc.
Im not sure if the file Im working is corrupt. When I open a clean file it seems to work fine. Ive been trying to compare my settings between the clean file and the one I am working in.
Any ideas? Help!
-Ben
Re: Wiggle line type
Thu Dec 10, 2015 1:00 pm
Have you tried to reload the line type?
Linetype/Manage pick line type then Reload
Thu Dec 10, 2015 2:25 pm
by MtnArch
Are you sure the linetype you're using is "Wiggle"? Where did you happen to pick it up? Maybe try the "Ruffcut" linetype (I believe it's a standard DT linetype) and see if it behaves the same?
The "Wiggle" linetype that I purchased (old Madura Studios Pro pack? Cheap Tricks? don't remember) had separate ones for a dashed wiggle, a centerline wiggle, etc.
Thu Dec 10, 2015 5:10 pm
by beneastman
Roger, I tried reloading from linetypes and it crashed. Im thinking something is buggy in this file.
MtnArch, I believe wiggle is part of the standard lintypes that came with DC. Im running DC 17, but have been using wiggle for years.
Thu Dec 10, 2015 5:36 pm
by beneastman
I purged the drawing and it seems to be working correctly for now.
Thanks for the assistance.
-Ben
Thu Dec 10, 2015 5:40 pm
by David A. Giesselman
Ben:
Try disabling the display of user lines (U in the SWOTHLUDFBK toolbar or from the Display menu. Then try reloading your line type from the Manager.
Thu Dec 10, 2015 6:06 pm
by beneastman
David that seems to have worked. I disable "U" like you said, then reloaded "wiggle" . Prior to that whenever I would try to reload wiggle the file would crash. Thanks!
-Ben
