Printing to PDF in Windows 10
PostPosted: Tue Jan 12, 2016 2:27 pm
by Gaddell
Recently after upgrading several stations to Windows 10, we noticed
a problem. Some of the stations can no longer plot to PDF format.
I am attaching a screenshot of the error message below. The worst
part is that it also aborts out of the current drawing. I have thoroughly
checked all the plotter and print settings. I am hoping someone out
there has run into this as well and has found a solution. We need this
to work as we sell PDF copies of our work. Any help you can give is
greatly appreciated.
John R.
( as Windows 7 is already being phased out, going back is not a preferable option )
Re: Printing to PDF in Windows 10
PostPosted: Thu Jan 14, 2016 9:49 am
by Gaddell
After talking to support, I was told that the update should
fix this issue. After applying the update to the affected machines
the problem is now fixed.
Thanks DataCAD support. !
