Hello Roger,
Please be more specific. If you say that you are using 'Entity' or 'Group' I can understand that you are 'selecting' objects.
Since you are selecting, I suppose you have, at this point, already entered a command, like Erase, Move, Copy, etc.
To enter in the command (Move, Copy) is that you are NOT being able to use shortcut keys ?
Or would be another command ?
The main shortcut keys, like 'm' for Move, and 'c' for Copy, are included on DataCAD's support files, and the main external shortcut file is DCADWIN.MCR which is located in the '\Support files' folder.
I hope you can elaborate some more on your difficulties.
