#69156 by cadline
Thu Jun 09, 2016 10:54 am
When I export a building model with smart walls and smart windows to DWG and open this file in Sketchup, the walls and windows have disappeared.
Ultimately, we need to import the building model in Lumion for animated fly thru.
It is for this reason we have to import to Sketchup and then export to *.IFC format.
Any advice how to fix the smart wall and smart window problem?
Many thanks for your replies.
Regards Eugene
#69161 by joshhuggins
Fri Jun 10, 2016 2:03 pm
In the Program Prefs, on the DWG Export tab, do you have the Auto Extract options checked?
#69163 by cadline
Sat Jun 11, 2016 6:11 am
Hello David,
Sketch up was only a vehicle to write a *.ifc file to be used in REVIT.
We also wrote *.skp files which took longer to save.
However, we have now selected the Auto Extract 3D option as you suggested and it worked.
Many thanks and regards, Eugene
#69164 by cadline
Sat Jun 11, 2016 6:13 am
joshhuggins wrote:In the Program Prefs, on the DWG Export tab, do you have the Auto Extract options checked?
Many Thanks Josh, we have selected the Auto Extract 3D as you suggested and it workd.
Best regards, Eugene
Users browsing this forum: No registered users and 91 guests
