New Window & Doors
Posted: Tue Aug 02, 2016 8:50 am
When creating new smart windows and doors from scratch - drawing slabs, assigning materials, rotating to vertical, saving to a symbol and then select the 3D (Use Symbol 3D)option in the smart door or window creation option. When I draw/create a new window from scratch do you always see the window or door from the outside or inside. So when you insert it into your smart window or door your view will always be from outside or inside.
Phew.....I hope I'm clear
