importing autocad files
Wed Aug 31, 2016 7:28 am
by pilot_n7731p
I work on datacad 12. it has become a problem to import the recent autocad files. I have to get the files backed to 2007 or earlier to get them to import properly. Is there any solution to this problem.
Re: importing autocad files
Wed Aug 31, 2016 8:00 am
The best thing to do would be to upgrade to DataCAD 18; as the DWG import/export is as up to date as possible.
If you search this site, you should find a good third party program to possibly save new DWG as older formats.
Wed Aug 31, 2016 12:54 pm
by RParker
There is a conversion program, believe it is called DWG TrueView, that will backwards convert dwg files.
