SWOTHLUDFBK appears in Coordinates bar
PostPosted: Sat Dec 03, 2016 11:58 am
by greenbergman
I just upgraded to v19 and SWOTHLUFBK now appears in the Coordinates Bar(third bar from bottom, not sure that's what it's called) as well as the usual place in the second bar from the bottom. It hides parts of the usual info on that bar. (See attached screen shot) How do I get rid of it?
Also, I don't recall having the icons to the right of the original SWOTHLUDFBK. Are those new?
David
Re: SWOTHLUDFBK appears in Coordinates bar
PostPosted: Sat Dec 03, 2016 12:05 pm
by greenbergman
Playing around, found that I can move it to the left side (see new screen shot) so at least it doesn't block info. But it's still repetitive - though more prominent, which isn't necessarily a bad thing.
PostPosted: Sat Dec 03, 2016 12:58 pm
you can turn one off if you want.
Tools/Toolbars one is icon based, other is text based.
PostPosted: Sat Dec 03, 2016 1:34 pm
by greenbergman
Oh, found it. I'd looked in Tools/Program Preferences/Toolbars. But it's in View/Toolbars, which I hadn't seen.
PostPosted: Sat Dec 03, 2016 2:05 pm
I have moved all my bars to the top and right of the screen, then I'm not bending my neck down all the time to see them.
