Text line spacing...
Mon Dec 19, 2016 1:49 pm
by Tim Mohr
For some reason the default text line spacing (Line: 1) is stacking text directly on top of the line below it without any space between. I haven't changed any settings that I am aware of so this is something of a mystery...anyone have similar issues (DCAD 19)
Re: Text line spacing...
Mon Dec 19, 2016 1:51 pm
by Tim Mohr
should add that when I check properties for text in question it says that the text is set to "text:line feed" - turn that off it corrects the issue but there is no way to do this prior to inserting the text into the drawing (as best as I can tell) ...is this an ini issue?
Mon Dec 19, 2016 2:22 pm
by David A. Giesselman
On the
Misc tab of the
Preferences dialog, uncheck these 2 options.
Mon Dec 19, 2016 2:54 pm
by Tim Mohr
thanks ...that did it
Thu Dec 22, 2016 10:32 am
by mrupsis
Thanks for that tip Dave! That was driving me nuts since I installed 19 as well...especially with knock-out on,
